going offshore for the first time
456
Hunter 31 Seattle
Doing a delivery from Portland to Seattle this long weekend. Friends 80's era tartan 41 he has refurbished.
6 of us all good sailors inshore but not one with proper offshore experience. Been in all kinds of conditions inshore including gales for shits n giggles to see what its like.
any advice for us? I'm confident in our abilities as individuals and even more the bunch. We've gone over the list of things to bring and checked it twice. Boat is rather green though and un tested which makes me a little worried. He says the rigging is less than 10 years old and they recently repainted the bottom and made sure it was all up to snuff but its a new boat to him (4-6 months?)
Jared
May 23, 2013
2
Hunter 37.5 Marina del Rey
Make sure you have extra fuel filters. Check engine to make sure it fires away from dock power. Do pumps work? Life jackets for all. Emergency kit. And weather. Have fun
Paul F
Jun 3, 2004
827
Hunter 1980 - 33 Bradenton
Make sure everything on deck is tied down and secure. An Eprib is a must.
Apr 19, 2011
456
Hunter 31 Seattle
Epirb, spares, functioning pumps are taken care of. So far the weather windows is looking good!
Jul 25, 2007
320
-Irwin -Citation 40 Wilmington, NC
Have and use safety harnesses, (I have a rule no peeing over the side this is when you get careless) Take meds for seasickness, use ahead of time if not sure. Reef before dark the other suggestions are good too, and most of all have fun!
Apr 8, 2010
2,137
Jared
Popular trip... !
I have two deliveries scheduled for June, same route.
We plan on assessing the sea conditions the first part of the route, Astoria to vicinity of Grays Harbor, and if we see any significant remnents of Japanese housing/boats/docks or other similar debris, we will spend a short night @ Grays Harbor. Same decision-making procedure for the next leg... leave Grays @ O Dark Thirty, and if we don't like what we are seeing/dodging in the daylight hours, go into LaPush for a night. Next day easily get 'round the corner and down the Straights.
We usually do this non-stop to Neah Bay in about 30 hours, give or take, but safety is way more important than schedule keeping.
Do your own inspection before leaving the dock on an unfamiliar boat... locate the thru hulls and open and close each one. Locate and check the gauge on all extinguishers. Need enough gumby suits for all OR a lift raft with current inspection sticker.
Always clip in when leaving the cockpit,and always clip in on the night watch. Take a small flashlight that easily fits a pocket. Same for a whistle -- attached to your pfd. Wear a combo PFD/Harness. I like the newer hydro-release inflatable PFD. (No more damp-attracting pill...)
Take along some sea-sickness pills or a patch. You might not need it, but if you do you'll be darned glad to have it. For that mild green-around-the-gills feeling, we find that candied ginger helps a bit, as does drinking some ginger ale.
Top Ramen is great on a cold day. Have the boiled water on the ready in a pump pot. This is also the one time that it's permissible to admit that you really do like Dinty Moore Beef Stew, hot off the gimbeled stove!
Layers of clothes - polypro stuff is great....
48 degrees @ 0300, in high humidity, will abso-fricken-lutely chill you to the bone while sitting in the cockpit.
insulated boots are better than thin ones! Wear Warm gloves or mittens.
Enjoy!
ps: many good 'net weather sites to look at, but one of the best ones I've found for interpreting wave period/height, and wind is surfing-oriented (!) site with excellent annimations. http://magicseaweed.com/
Click on "Oregon" and choose your date for display.
Cams: darned few that look out onto the ocean off the WA coast, but here's one just south the Grays Harbor jetty, http://www.rainbowsendcam.com/weather.htm
And the two @ LaPush,
http://forkswa.com/james-island-webcam/
http://forkswa.com/first-beach-webcam/
Apr 19, 2011
456
Hunter 31 Seattle
your spot on fastolsen!
we sailed past the bar at slack tide and rode downwind to neah bay with 10-15 knot winds 90% of the way.
everyone was feeling sick in the first 2 hours but took more sea sickness pills and it went away.
what a great trip and learned so much. Found I really want to get a compass mounted somewhere forward so you don't have to look down. It was nearly impossible to stay within 30 degrees of our heading without staring at compass the entire time.
I'm also going to change my boom vang so I can quickly move it to the toe rail to act as a preventer. Accidental gybe in those lumpy seas is very worry some threat. Luckily the boat we were on had it.
more layers of clothing was needed. I swear every time I think my foul weather gear is solid I find more ways of getting wet.
2 hour watches with 6 hours down was nice. I'd not do this trip with less than 6 people.
I need to get a line cutter on my shaft. We had to dodge no less than a dozen crab pots. line cutter is a must for me now.
Jared
jbinbi
Apr 17, 2013
38
hunter 33 MA
just to add to the above:spare raw water impeller! always sail with extra one for long journey.
May 23, 2013
2
Going north from LA to Portland. Any suggestions. Go west 200 miles then north or hug the coast line. 37 sailboat
Try this: http://georgebenson.us/
The narrative (now a book) about his trip up the coast from SF to Seattle is worth reading. The Cruising Narrative not so much since it just has lists of charts, although the two together are good companion volumes.
Apr 8, 2010
2,137
I bought this book last year. Good reading, and it's great to have 'real world' information.
Loren
