Go speed racer go!
bryan
Anyone have any good suggestions on how to get a very tight, very sticky speed transducer out for cleaning. And how to keep the seal for further cleanings? Thanks to all
Jim LeBlanc
Wait to clean
Must have severe marine growth, if you cannot pull it easily. Better wait until the boat is out of the water, clean from the outside, then gently push it through to the inside if necessary. The normal rubber seal does the trick if you remove and clean the paddle wheel periodically.
