I started racing our 2002 H270 & have a need for speed. Tips would be appreciated. I have been advised that going downwind with the Hunter B&R rig, that it is generally faster to jibe than sail directly downwind. I also found the following tip:
"If you sail non-spinnaker, put an additional woolie or telltale two-thirds of the way up the sail and halfway between luff and leach. Make sure the LEEWARD telltale is streaming aft. Especially on a reach this shows the amount of twist to put in the main. If it is not streaming, let the boom lift until it does. It works. After Greg Fisher showed us this secret, my reaching speed improved so much that my Windmill was measured after an event. They thought it might be underweight."
