Not wrong, just not necessary
MichaelThink about how it works.The glow plugs heat up the chamber for when the pistons first start going up and down from the starter, they have a HOT chamber that helps the fuel to ignite. Remember that there are no spark plugs in diesels.You don't need to keep the glow plugs hot at the same time you hit the starter. The few seconds between stopping the glow and hitting the starter will not affect the purpose of the glow plugs.That's why, for instance, hot engines will start without the glow plugs.The 12-15 seconds (with solenoids) or 30 seconds, without solenoids, will be enough to heat the chambers for ignition.No need to keep them both going at any time.You might even find that your engine turns over more quickly if you release the glow plug button before you hit the starter.Stu
