Globe impeller failures
The Globe impellers sounded great to me, but my yard mechanic said that he had seen failures of them after installation. But I wasn't going to be talked out of it, so I called Globe and asked them about it. They told me there had been a problem at one time, but that it had been corrected. So I bought one and installed it. It failed during operation after about only 50 hours.The type of failure I experienced is the same as others had reported. The plastic hub of the impeller separated from the impeller body. This meant that the hub kept turning, but the impeller blades no longer did. If I hadn't been alert to the lack of water coming out the exhaust, I would surely have overheated. I was able to shut the engine down and do a replacement of the impeller while out on the water.Shortly after asking about this on a Catalina listserve, another owner emerged who had experienced the same problem. He said that Globe offered to refund his purchase price, but that he hadn't seen any money after 1 month.The idea behind the Globe impellers is great, but how can you know when they have finally gotten it produced right?
