Winkfish, who sails out of New Orleans (my favorite city), asked about this subject.
There are 3 simple ways to “get out of irons”, but first some basics. A rudder needs steerageway in order to work and unless water is moving against the rudder it is useless. So we have to get the boat moving and the only option is backwards. The slightest bit of backward motion will make the rudder effective. Once you get the boat moving backwards ever so slightly you have to do something with the rudder and the best option is to center it. Why is that? The reason is you want to start drifting/sailing the boat straight backwards. Turn the rudder at this point and you’ll kill what little speed you have. Once the boat starts moving backwards you’re half way out of irons. As you start to pick up a little speed you should start driving the boat backwards.
OK, now we have the boat moving backwards (I’ll explain how to do that in a minute) so we want to reverse the rudder. This is easier to understand using a tiller. You point the tiller in the direction you want to go. With wheel steering you point the stern in the direction you want to go.
The first way to get out of irons is to “back the main”. Shove it out 30 to 40 degrees until it fills in the direction OPPOSITE you want to go. If you want to go right push the main to port. Backing the main is not the best choice and that is because of its location in the center of the boat. It lacks leverage - sort of a seesaw.
The second and best way to get out of irons is to “back the jib”. If you back the jib to starboard the bow will swing to port and vice versa.
Guys like Alan, RichH, Joe from San Diego and other listers on this forum use “irons” all the time as a starting line racing technique and even while docking. RichH can sail his boat backwards over a good distance as well as he can sail it forwards!! All it takes is a little practice and anyone can do it. Don’t wait to learn the technique as I did with the boat 100 yards from a breakwater. I have no idea how I got out of the mess the first time it happened.
So what is the 3rd way to get out of irons? The answer is DON’T DO ANYTHING!! Beginners don’t like this method because they are not aware of what is about to happen to the boat and they panic – like I did the first time it happened. Eventually, and shortly, the boat will start moving backwards by itself. When that happens just reverse the rudder, trim up and sail off.
Practice putting your boat in irons and getting out of irons. Once you master the technique you move up a step in seamanship and you are controlling the boat instead of it controlling you.
