Putting it all Together
All right, this project is part of my evil (to some) ideas about the plane-ability of the 26D hull. The fact that multiple persons posting on this list have gotten their 26D's to go faster than the theoretical hull speed should raise the suspicion that this hull shape is NOT a "pure" displacement hull. Anyone who squats down and looks at the hull when it is on the trailer will see a hull that looks pretty similar to any other planing fisherboat. Now here is where it gets a little weird: what if the 26D would plane or at least go faster than 10 MPH with the ballast tanks empty and on the kickers push alone? Yes, it might be tippy, but so is my brothers aluminum boat. Yes, the boat might not be suitable for (take your pick): insurance agents angry about flotation foam removal, little children who are so trusting and vulnerable and can't swim and don't have on their PFDs, your mother-in-law, etc. I am not inviting any of those onboard. I am very concerned about cavitation of the kicker in either forward or reverse. Maybe not cavitation, but the phenomenon wherein the motor seems to suck air at the prop, and is less effective. I just realised how ineffective my kicker is in reverse, I have to test the reverse performance some more to see what is happening there. Last night, my brother dropped off a Stainless Steel shroud with a 9 in diameter and a 4 inch length. I will be fabricating spacer blocks out of HDPE to center the ring around the 8 inch prop, as I can no longer just mount the ring on the anti-cavitation plate. It is very thick SSteel, but I still want to pick up a brace on the skeg as long as I have already drilled a clearance hole for a #10 machine screw. By the way, some shrouds are put around props to protect the propellor, some are there to protect swimmers and even manatees, not all are performance enhancers. I think I probably do more damage to my prop while removing the engine from the transom and transporting it, than I ever did by hitting something under power.
