Getting juiced
walt
Jun 1, 2007
3,556
For the three wire case,
Green SHOULD connect to the toaster chassis. Both black and white should be completely isolated from the chassis.
walt
Jun 1, 2007
3,556
More speculation regarding the three wire toaster plug since no measurements..
Assuming your toaster is fine, another possibility that I would be surprised with.. but one of the two inverters I had would have done this..
On your inverter, un plug it and take an ohm meter and measure between the AC output earth green and the DC 12 volt ground into the inverter. If this connection is an open (which was the case on one inverter I have but not the case on the second inverter), the green wire on the inverter output is not connected to your boats ground like it should be.
In this scenario (which we dont know if it is the case.. more speculation), the floating green out of the inverter capacitively picks up the AC signal and if the toaster is wired correctly, the floating green wire that has the coupled AC is connected to the chassis of the toaster.
This is not really dangerous (except that it would be for a real fault) but the capacitive coupled AC on the toaster chassis would result in a mild shock if you touched it and anything else related to the boats ground.
Jan 30, 2012
1,154
Nor'Sea 27 "Kiwanda" Portland/ Anacortes
According to wife-of-capta there is no touch potential when the oven is plugged in to any other inverter powered AC outlet - just the new one.
Also the wife meter measures tingle so the current passing through her is somewhere 1-5mA
Do these facts help?
walt
Jun 1, 2007
3,556
A properly working/ wired toaster where the AC green wire is connected to the toaster chassis (as it is supposed to be with a three wire plug) and with the green wire just floating and not connected to anything on the other side, you could have a situation like the tingle. The green wire likely runs next to the black and white wires with AC voltage for some length in a sheathed bundle and could "capacitive" pick up some of the AC. The parasitic capacitance is not large so the currents are small and not dangerous.. but you could feel a tingle.
In the case above, if the AC earth green wire was connected to the boats DC, that problem would go away.
