Genset on a Beneteau 473
R Frank
I am considering installing a 5kva Kohler genset on a Beneteau Oceanis 473. There does not seem to be an ideal location in the boat for this, although I have seen some being installed on the locker at the starboard quarter, just fore of the transom (it fits there a bit too snuggly for me - very difficult to access and to service). Any experiences with this that can be shared with me?
mjb
Oct 12, 2005
63
Beneteau 473 Huntington, NY
factory install location
I believe the standard location for a factory installed genset is the starboard aft quarter.
Jun 16, 2005
476
- - long beach, CA
gen-set
I think it the height of design neglect not to have at least a dedicated location in the engine spaces for a genset on a boat over 45 feet. You'd think Beneteau would know better. (I use a Honda EU2000i on my 40 footer)
Beneteau 473 owner
Genset on Beneteau 473
I have a factory installed Westerbeke 8.0 BCDT in a Beneteau 473. It is in a sound proof enclosure in the aft quarter locker, as you suggested. Also as you suggested, it is pretty cramped for access. I am 6' 1", 57 years old and used to be slimmer and more flexible. I did change the oil and filter this summer, and it is doable for me, but not fun. I would rate the difficulty as somewhat less than getting at the steering chains through the cockpitlockers, to give you a sense of it. So, there are other things that are cramped for access in any boat. This genset is not particularly worse. But it is a compact genset, and I would not want a bigger one. One maintainer I respect basically said "some jobs need small mechanics with strong arms". Maybe, if you can afford the boat and genset, installation and maintenance of the gensset are jobs to have done (by strong little people with the right gifts, unless you are one of those). The Beneteau USA factory installed the new model genset in such a way that the enclosure could not be removed at all. I understand they did this to others as well. The dealer cut the enclosure to make it removable (now) for engine service. I assume that the factory is now doing a better job. The wiring, grounding and fusing is pretty complex to think through. So, if you are having after market installation done, make sure it is done well. Hope this helps
