GENOA LEAD TRACK,
DON GORDON
In order to improve pointing, I have decided to add an inboard lead track on deck. The toe rail track does does provide a tight enough sheeting angle. Any suggestions from those who have done this already would be greatly appreciated. Specifically, location longitudinally as well as athwartships, length of track, angle to centerline, means of securing, through bolt through both layers of fiberglass, backing plate versus washers, interference found with fw fill tube, or with overhead mounted cabin lights? Also, any comments about improvements noted in performance would be appreciated. THANX DON GORDON EMAIL: don@captdon1.com
Tim S.
Genoa Track
Your length of track and fore and aft location will depend primarily on the LP of your Genoa. If it is an RF Genoa, you will need enough track to be able to reef down and move your lead position forward for proper trim. You can check with your sailmaker, for a small consulting charge, he can probably give you the sheeting angle from the bow for distance off centerline as well as fore and aft location and length. If you are considering a new sail anyway, he will most probably do this for no charge. A good rigger or boatwork expert can help you with proper backing solutions. Good Luck
H
henry Weber
Inboard genny track on H30
You might also consider an inverted Barber Hauler. It might accomplish the same improvement in pointing with a lot less effort. You don't need much more than a block and additional line. I sail the same boat and doubt that you will find a great improvement -- at least try it the easy way first. Best Henry
