I have a Beneteau 323. Main Halyard and Jib Halyard are good. Its my Spinnaker / Genoa Halyard. The jib halyard is a fractional coming out of mast about 2 feet or less from the head. The Spinnaker / Genoa halyard comes from the same place about two feet from the masthead. When i put up the genoa (a north sails C1 that must be rolled on a tension luff ) it gets too close at the top end with the furled jib. No problem with the spinnaker since it does not need to be rolled. The genoa tack is on a short sprit out front, about two feet, so there is clearance at the lower end. Its the upper end. I see a photo of what another owner has done with a "lift out" sheave. I asked two different riggers at a boat show. They said two options, the lift out and run the halyard up and over the sheave. Or "more simple" that there may be one or two sheaves at the very top of the masthead already and all I need to do is thread the halyard upwards in the mast from the fractional set up and out the mast head. In the photo I have, I do not see where the sheave may be exiting the masthead. I was also advised if I find a sheave up there, there will be sharp edges near the mast or on the mast that will shred a halyard in seconds. One rigger said it was a half day job no matter which way done.
My boat is up the BC coast and not near any rigging businesses and it would take a long time to get the boat near a rigger in Vancouver, so I am considering an owner job.
So questions: anyone else with a stock 2008 Beneteau know if there are sheaves up there.
What does one do to take the cap off the masthead with all that windvane and antenna gear up there to look for sheaves
If I find out if there are sheaves there, What does one do about the sharp edges?
If I do a "lift out and sheave" What type of hardware would i take with me from Vancouver, to do that. Stock hardware? What type of screws or bolts are used on an aluminum mast? Stainless or other? Screw in or bolt through only due to loads involved?
