Hi all,I'd like to get better light air performance on all points of sail and am considering a 120% to 130% genoa for my H260. This is to get input on what works well.I have a hanked on jib, and will get a hanked (no furling) on genoa to use on the light air days.So if you use a genoa, what size do you have and where do you have the sheet blocks located? I'm considering adding them just in front of the winch, perhaps outboard a little bit for a smooth run and to clear the existing line paths and hardware.I don't want to add a chute (as'ym or ASP) because I often sail singlehanded or with inexperienced crew. Also, the genoa adds speed, but no handicap, for the local PHRF fun races!Thank you for any help.Fair winds,Tom
