Gas Goes BOOM!
Although you're in Ontario I'm sure the Canadian Coast Guard has similar requirements at the US Coast Guard when it comes to puting gas stuff below decks.With gas engines on a power boat there has to be positive ventilation, electric fans, probably explosion/vapor proof rated, which have to be run prior to starting the engine.Probably the only way do to do this is to provide a fully enclosed space separated from the rest of the boat. This could be done but at an expense. Then there is the fuel storage and difficulties in refueling. Either one uses the built-in fuel tank or has a separate one with a CG approved fuel line running to it. The exhaust on the Honda generator sticks out just a fraction of an inch so there is a very small stub to attach an extension to. There would need to be a fan to force air through the genset then outside for cooling.When you say the generator is "quiet", that's relative. When a dealer demo-ed a EU1000i out on the sidewalk it sounded quiet. When I had it on the dock next to the boat it was NOISY! On the sidewalk there were cars going by and so by comparison one could say it was quiet. Solar panels and wind generators are the only way to go - easy for me to say because I don't need air conditioning. Running air conditioners and refrigeration units take more power and the EU2000i will probably not handle it!What I'd really recommend is something like the Entec diesel generator with a waterlift muffler. Entec generator details: http://www.entecwest.com/(also see same link below)Waterlift muffler available from Gallery Marine: http://www.gallerymarine.com/ Now this is QUIET but at a "cost": $$$, weight, and space. A great little unit.For the Honda generator: 1. Recommend having it OUTSIDE the boat so as not to deal with the myriad of installation problems, and,2. Refuel it after it has cooled off!3. Anchor away from other boaters (at least those without generators).4. Will CORRODE easily because it isn't marinized. Aluminum will turn white and the iron stuff will rust. If you're on the great lakes maybe it won't corrode as quickly.5. Cheap. But you (might) get what you pay for.Hope this helps - suspicions confirmed?
