I have a 2006 Hunter 45 CC, and a 8 KW Fischer Panda Generator, and have the following questions.
After starting the generator from the Fischer Panda supplied remote panel, and after the generator is running, I then switch on the "Generator" rocker switch located on the Hunter supplied small 12-volt DC / 120 volt -
AC electrical panel just above the nav. station, does that "rocker switch" activate a relay that is either inside or behind the large 120-volt AC distribution panel (with circuit breakers) which is located behind the port side seat cushons directle forward of the nav. station. Has anyone ever had to replace this relay?
Thanks,
Jeff
S/V Sooooo Lucky
Long Beach. Calif.
Thanks,
Jeff
S/V Sooooo Lucky
Long Beach. Calif.
