Genset for the 376/380
If you subscribed to Southern Boating Magazine you probably wouldn't be asking this question now. They had a great article in their May or June issue about the subject of Gensets. You may be able to pull it down off the internet. They reviewed several models and although they didn't give strong support for any particular brand they seemed to favor the more lightweight, higher RPM models which, they seem to think, are just as quiet when properly insulated.The one thing they emphasized was the importance of not installing too big a generator. The little diesel that powers a genset works best when it is under a load and an oversized generator which can run all your boat's AC needs at once is not going to put enough of a load on that diesel when running a couple of appliances, resulting in associated problems of carbon buildup, etc. Better to go with a smaller KW generator and (as an example) turn off the water heater when your wife wants to use the hair dryer to give the diesel a healthy workout.I had an Entec 4.2KW installed on my 376. It went into the port cockpit aft lazarette and as noted was too tall. The vender and my dealer had to cut an opening in the bottom and fabricate an aluminum box which extended into the aft cabin. It was water-cooled and very well insulated in its own integrated housing but it still made a lot of noise and vibration. The good thing was, it fulfilled all our AC needs and it masked the noise of the reverse transom slap at night.I recently watched my dealer (Florida Yacht Charters & Sales) install a Fischer/Panda 4.0KW in a new 380. They still had to make a few modifications but were quite pleased with the overall result. You may want to give them a call and get some feedback. (800-537-0050 ask for Ann Marie or Bob Everhard)Warren BlanchardSV "Banana Wind" H-460Abaco, Bahamas
