Genarator for Hunter27
Jacques
The next step to geeting an ac unit is to be able to power it while undrer way.. This means genarator time. Has anyone put a genarator on board a Hunter 27? If so give details... Jacques
tom r. evans-kennedy
honda 350 watt generator
i have a hunter 27 1980//i keep her on a mooring in halifax harbour and must keep the battery topped up all the time//i have two back ups to charhe the batteery other than the alternator on the deisel//i installed a small solar cell on the deck if front of the forwads hatch cover also i use a honda x350 2 cycle generator is produces 6 amps 12 volts//its light and easy to handle on board can charge at mooring or under way//lash the generator to the safety lines//its very quite and a great starter/it uses the same fuel 50:1 gas same as my outboard on the skiff//this has back up power sourse has keep me afloat battery has never failed to start the yanhmar
