Synopsis of article
If you don't get a copy of the article, as I recall it, the technique was basically to grind or gouge out cracks so they would be large enough for the gelcoat or epoxy to penetrate; seal with epoxy; spray on gelcoat with one of those little air guns; then finish up with 600-1000 grit wet sandpaper and polish.Gelcoat you can get from Hunter or the store work fine. I have fixed a lot of cracks, its not hard. I gouge em out, slap on some gelcoat with a paint brush, and the sand smooth finishing as indicated above, though I start with 100 grit to get the worst of the bumps out. I usually don't bother with epoxy unless its a particularly deep gouge. Works fine, it's easy.What is a pain in the ass for me is matching the gelcoat color. I've tried store bougt gel coat and gel coat I got from Hunter. Both looked like they matched at first, but after a couple days the store bought gel coat turned too grey and the Hunter gel coat looked to yellow. So while my patch jobs look find, you can notice a color differential.The CW article glossed over this issue, vaguely mentioning just matching the color by mixing appropriate pigments. If you can figure out how to make the color match, let me in on it. It may be with a sprayer you can feather the edge so the color blends in better....Good luck
