Gelcoat stain from Seagull poop
Kivalo
Jun 5, 2011
116
Hunter 260 Owasco Lake
How do I remove the discoloration on my helm seat from seagull poop? :evil:
Thanks in advance.
Brad
May 24, 2004
7,164
CC 30 South Florida
Stains on the non-skid textured surface are hard to get out. I would try bleach or some liquid abbrasive compound with a high speed cloth buffer.
Dec 2, 1999
15,184
Assuming you are speaking about fiberglass/gelcoat, I would suggest Totally Awesome ($1 a bottle at the Dollar store) or Simple Green.
If that does not work, then you can move up to Oxalic Acid, Soft Scrub etc.
Aug 11, 2011
954
O'day 30 313 Georgetown MD
I find Simple Green to be greasy and leave a slimy residue. Purple Power works really well.
Hunter 29.5 Gloucester, VA
I use Crud Cutter. Seems to work well on bird stains and the black stains from port lights. Also use on cockpit cushions.
May 25, 2004
958
Hunter 260 Pepin, WI
Clorox now makes a general purpose spry cleaner called "Clean up". I used it on all the tough stains in my cockpit. It really worked well on the seat cushions too. When I rinsed with fresh water I could see all the ground-in dirt just wash away.
I use Joy dish soap for the common dirt. I like it because it's bio degradable. Put a couple ounces in a bucket, fill with water, and then scrub away.
Jan 29, 2007
95
Hunter 22 Pelham Manor, NY (1981 H22)
I have been told that bleach products can yellow the gelcoat. Try putting a piece of bird netting in your spreaders and on the boom and halyards when you're not around to keep varmints away.
Apr 18, 2008
77
O'Day 34 Fairfield Harbour, NC
I bought some West Marine Bird and Spider Poop remover, and it worked very well, but a little pricey. My common sense First Mate used baking soda and a damp wash cloth, and got the same results for just pennies. We'll be keeping the baking soda on board from now on. Also, the WM spider preventative spray works pretty well at keeping the wee beasties at bay.
Hunter 23 Tampa Bay
I use sudsy amonia I get from Publix. Any one will have it. Mix it 75% amonia and 25% water. The stuff kiicks butt. I scrubbed some serious pelican poop yesterday!
