Gel coat stain
H
Herb
Hi there I almost lost a wheel on the trailer this week ( another story) but everything was saved with what could have been a big problem being a little problem. But now I have a residual problem the wheel bearing when it gave way splashed bearing grease on the hull. I have cleaned it off but still have a grease stain. What do you think would take this off . it is about 3 inches around where it spite the grease out of the hub. thanks for your input.
Bryan
elbow grease
Sorry about your bearing lube stain. Try island girl's pink stuff to take it away. Maybe some 3M product might work as well. West Marine or Boat US shoul have a product. Just remember you will take off the stain and wax as well, so you will need a product to put back on after it is clean. Maybe polyglow had a product. I am only familiar with Island Girl and 3M right now. But many post seem to like other products. But don't fret it will come off eventually. Good Luck
Jim Willis
Grease is pretty easy!
If you already have then, you can use any IG cleaner, usually with just paper towel. A little caustic i n grease cleaners also helps so try Krazy Clean, or Castrol Superclean too. Thanks Jim W
