I require a gel coat filler in a colour that will match the gray of a
Vega deck. Because the deck has faded, I expect the solution is to
find a colour pigment that can be added to the white gel coat filler
(readily available). Where can I get such a pigment ?
When using filler on the off white topsides, I have had good results
simply by using yellow hardener in the white filler.
