Gel battery Question
Jun 29, 2010
1,287
A boat I am interested in has a gel battery. The issue being, everything has been sitting for about 3 years. I have no idea if they have kept it on a charger/conditioner for the 3 years, my thought would be no. I think the battery was used for a couple of years before being left to sit. Should I juts consider this a loss and plan on replacement or can it be saved?
Beneteau 323 Annapolis MD
At the minimum, check it with a volt meter. Ya just never know what you might find.
7,569
Alden 50 Sarasota, Florida
purchasing a boat predicated on the useful life time of its battery is a novel concept.
Regardless, gels usually hold a charge longer than wet cells if that helps.
Feb 6, 1998
11,722
Cycle them deeply under a load that is close to their 20 hour rate (Ah's divided by 20). Bring them down to about 10.5V or so then recharge them immediately at a rate close to the 20 hour rate. Repeat this twice and you'd be amazed how a GEL battery can survive...
Max charge voltage is 14.1V and float should be 13.8V
Jun 29, 2010
1,287
Ummm the battery really has nothing to do with whether I purchase the boat or not. I was just wondering if I should just dispose of the battery and get a new one.....
Jun 29, 2010
1,287
Thanks!
