AGM not the same as gel cell
AGM's are touted as the next generation: All the advantages of both gels and flooded. There is some truth to that, but all batteries die eventually, and eventually is further in the future the more you control the charging cycles. I highly recommend the Xantrex products, as I have staked my life on them in extreme situations on more than one occasion (and obviously haven't regretted it....yet). A top-end battery charger will allow you to realize the advantages of gel or AGM batteries.That being said, the cost of high end batteries, amortized over the extended life of those batteries, is about the same as the cheap, shorter-lived batteries. Over a prolonged period (say 10 years), you will have spent roughly the same amount of money on batteries no matter which kind you buy. In the case of the AGMs, you will have had half as many instances of potentially inconvenient battery failures during that time.
