Gearbox: glaze cone?
Oct 29, 2005
2,362
Curiouly how does one cause his Kanzaki gearbox cone to glazed?
Sep 2, 2011
1,041
Hunter 27 Cherubini Alum Creek State Park
In my case, a PO had used ATF fluid instead of the factory spec same oil as used in the engine!
I pulled mine out and will be rebuilding it over the winter.
Oct 29, 2005
2,362
GT, thanks. For past 2 years when ever I put gears to forward or reverse the first time, I get grinding noise. Didn't know what causes it. Assume its barnacle on shaft and cutlass bearing. It goes away after coupling minutes in gears and fine for rest of the day.
wonder if that's the start of glazing problem.
