Dave
I have a 2002 H356 with the 27hp Yanmar engine. When I checked the gear box oil dip stick, I am not sure where the high and low fill marks are. On the dip stick, there is a line about 1/4" from the bottom. Then there is a hole 1/4" down from the top near the cap. The dip stick is hollow as well. The oil level is at the low line on the dip stick and I am having no problems and have no leaks. Just thought I would ask others what you are using for high and low marks.Thanks
