Gasket for M-18 rocker arm cover
Jun 11, 2004
1,767
Oday 31 Redondo Beach
I want to adjust the valves and torque the head on my Universal M-18 and was thinking I should have a new rocker arm cover gasket on hand before I do this but am having a bit of a hard time finding one. Will I definitely need a new gasket or can I get away with the old one.
Thanks
www.marinedieseldirect.com will have it, but at marine prices. You have a Kabota tractor engine. If you know the engine model for a tractor, go to a tractor dealer. If you don't know the engine model equivalent, use Google and find out. Good luck.
Feb 8, 2014
1,300
Columbia 36 Muskegon
That's a Kubota Z600 engine used in the B4200 tractor. Your local Kubota dealer or online tractor parts site will have parts for about 1/4 the marine prices. Same exact parts. They need the tractor number to search.
I usually cut out my own gaskets from material bought at the auto parts store. A bit of work but very inexpensive.
weinie
Sep 6, 2010
1,297
It's a rubber seal.
Mine was still good after twenty five years when I did a valve adjustment.
Jun 11, 2004
1,767
Thanks for the replies. I should have said I was having a hard time finding one locally. My regular suppliers don't have one and I didn't want to wait the time for shipping or pay the expense. I know it is a Kubota Z600 engine but we don't have a local tractor dealer here in Los Angeles (at least that I can find).
Weinie's response is encouraging so I may try to do it and reuse the old gasket. Hopefully the worst that could happen is a minor oil leak that I could live with until I got a new gasket.
Thanks again for all the responses.
Feb 8, 2014
1,300
If its rubber you'll probably be OK. Old cork or paper gaskets are hard to remove without tearing them.
