Explosive vs. Flamable
Great idea, fact vs. fiction. Not sure of the stats on the insurance risks and exposure, but as a safety professional for over a decade, I've had some experience dealing with the liability surrounding gasoline and diesel. The first web page I found was:http://www.madsci.org/posts/archives/nov2001/1004991364.Ch.r.htmland contained the following, ". . . all gasolines and similar hydrocarbon liquids will have flash points below the freezing point of water. This means that at ANY reasonable ambient temperature, there are dangerous quantities of fumes above any substantial amount of the gasoline."What does this mean? Well, liquid gasoline isn't the problem; it's the vapors just above the surface. Gasoline burns real fast - so fast, in fact, that the burning is better described as an explosion, which is actually just rapid combustion.The 'boom' from a gasoline explosion (real fast burning process) is a result of the surrounding air being pushed outward from the rapidly expanding, burning gasoline vapors. This process is so powerful; it will turn a fiberglass/wood boat into splinters in an instant. Here’s the catch. The gasoline vapors are heaver then air and will collect in your bilge. This vapor is what ignites in the low center of your vessel. I recall picking-up pieces of a 45’ wood cruiser that drifted ashore after she exploded from such a ‘rapid burn’ of the trapped vapors in her bilge. The MSDS information on regular unleaded posted on http://hazard.com/msds/f2/bhf/bhfxy.htmlIs as follows:“Unusual Fire/Explosion Hazard: VAPORS ARE HEAVIER THAN AIR, ACCUMULATING IN LOW AREAS, TRAVELING ALONG GROUND AND MAY FLASH BACK FROM DISTANT IGNITION SOURCE.”This means that anywhere you have gasoline stored: your boat or even your garage for example, this trapped vapor may exist. Combine that with a spark from a broken spark lead on an inboard, or a pilot light on a gas water heater and boom! That’s one reason that you’ll find fewer boats with gasoline inboards and the water heaters in newer homes mounted almost a foot above the floor – just in case your garage remains closed with your stored lawn mower fuel can.As far as diesel, this stuff’s certainly flammable, but not explosive. In other words, diesel will burn, but not as fast as gasoline – you almost have to give it a kick to ignite (glow plugs. . .)To give you an idea of the difference, in a gasoline car engine, the typical compression ratio in the engine is 8:1. In a diesel it’s around 23:1 taking more pressure on the diesel to create a usable burn in the engine.Go with the diesel if you’re getting an inboard. I’d avoid the gas like a plaque. You guys reading this with a gas inboard probably are taking ample precautions like a ventilated bilge, etc. to reduce the possibility of vapors collecting and waiting for that spark. Please be careful with gasoline. It’s as safe as you make it. Besides, you’re in far greater danger of maiming simply driving to your boat to enjoy a sail then you are of having your boat explode. Never the less, the risk is real.
