Gas solenoid valve
1
- - newhaven
Hi All I havce a 1999 340 and the gas solenoid valve coil is overheating the result is the gas flow is much reduced ( now almost useless) Questions 01 Is this a common fault? 02 The coil detaches by one circlip from the body of the valve , if I replace this coil will it solve the problem? or does the whole valve need to be changes ? 03 I am in UK does anyone know where I can get this part over here? 04 The coil id a Parker hannafin item Thanks in advance John
Al9586
May 23, 2004
55
Hunter 356 Orange Park, Fl
we had to replace ours too
We had the same problem on our 356 after about 2 years in service. I ordered the whole solenoid, including the coil, replaced it and it works fine. Found that the unit as was installed by Hunter was "hard wired" so I added a bus bar to facilitate replacement next time.
Jul 29, 2004
413
Hunter 340 Lake Lanier, GA
Replaced ours, too
Also have a 99 H340 and the LP gas solenoid failed last summer. Symptoms were that the stove would light but gas flow decreased to nothing after a few minutes. Your description of "overheating" makes sense. I found an exact OEM replacement for the whole unit at one of the online boat parts sites (Sailnet?) Ed
