I have a Garmin 182C with a sonar GSD 20 and it started to flash the depth as though its not seeing the bottom and then would completely stop so I checked the transducer for growth and found it clean then I took both the sounder and chart plotter to a friends boat who has the same set up and all worked well so it must be a wiring problem between the sounder and the transducer or the transducer.I took the connector end and cut away the rubber to expose the solder connections to check for continuity and all is well, the cable is still secure throughout the bilge area from the day of installation a couple of years ago.*oI’ve ordered a new transducer so I can check the system before I haul out for the winter but has any one ever heard of a transducer going bad? BTW I also have a temperature sensor on this transducer and it works fine
