Garmin radar owners - noise?
3,562
Endeavour 32 Portland, Maine
My Garmin HDR 18 / 3205 combo has has so far worked beautifully with just one glitch. Near the end of my last cruise, I turned on the radar in clear weather to see what a certain target looked like and there was no radar. It looked just like the power switch to the radome was off. I tried the usual cable wiggling, restarting, menu checking, etc. Nothing would get me radar. I didn't really need it so I turned it off and waited until the next morning to troubleshoot.
The next morning, it worked and I have had no trouble since. However, just after I turned it on a noticed that an outboard boat was going by nearby on the very quiet morning. The instant I turned off the GPS, the outboard boat stopped. I realized that it was the radome which now makes a fairly loud grinding, whirring sound. I can't hear it under power or sail but I don't remember any sound when I had it set up in the shop at installation with the radome hung from the ceiling just overhead.
It's worked find for the few days since but I'm wondering what the typical noise level if for other users and if this apparent increase in mechanical sound could indicate imminent failure.
Incidentally, the 3205 does send a signal to the radome to shut down when you turn it off. The radome does start up briefly when the 3205 is powered up but the mechanical noise stops when it goes into standby mode. Powering up the radome with the 3205 does not produce any noise or other indication that power is flowing to it.
Tim R.
May 27, 2004
3,626
Odd Roger. I never noticed much, if any, noise from mine. My previous radar(furuno) did make some noise.
Isn't there indication on your CP screen that the radome is in standby?
Nov 22, 2008
3,562
I haven't looked to see. I don't use standby mode much to minimize power draw. I just turn the breaker to the radome on when I start it up and off when I don't want radar anymore. If I turn the radome breaker on while the GPS is running, it goes though the whole count down to Standby and startup routine.
My radome is up on the mast so sailing sounds easily mask the current noise level unless you go up and put your ear near the mast. It's loud enough though that I'm sure you would have noticed mine if it was mounted right overhead as yours is.
My concern is that the odd radar blackout was the antenna being mechanically stuck and it was jarred loose by the next morning but is now compromised. I'd love to ask Garmin about this but what are the chances....
Tim R.
May 27, 2004
3,626
I do the same with a separate breaker. That does sound suspicious.
Rick D
Jun 14, 2008
7,183
Sure Sounds Like A Mechanical Issue in Scanner
nm
Nov 22, 2008
3,562
While discussing the GPS date problem with Garmin tech support (which is suddenly answering the phones quite promptly) I asked about the noise in my radome. He said they use a toothed belt for the drive and it is noiser than the smooth belts in other units but longer lasting. He said a "grinding" noise (exactly the same word I used) is normal and may get a bit louder with time.
