Garmin GPS and S1 Wheelpilot Interface Cable
G
Greg W
I am installing an S1 Wheelpilot and would like to run the cabling which connects to my Garmin GPS allowing them to communicate. Is the S1 computer connected to the GPS through or by a SeaTalk Cable? Greg W.
BobW
Jul 21, 2005
456
Hunter 31 San Pedro, Ca
Going from memory....
The S1 is a Raymarine autopilot (I have the ST4000) and Seatalk is a proprietary Raymarine interface, so it only works with other Raymarine equipment. However, you CAN interface the two units using NMEA 0813, which will send cross-track data from the GPS/plotter to the autopilot. You don't need anything special as far as cable is concerned - especially stay away from anyting that is branded, packaged and labeled by one of the manufacturers. Just plain marine grade signal wire (I THINK it is only a single pair, but your owner's manual will let you know for sure) is perfectly adequate. I also doubt that the data rate is anywhere near where you would want/need shielded cable. I made that connection with my Garmin GPS, and it works just fine. Watching the GPS and autopilot work together (rather than fumbling with charts, sightings and steering) is just plain FUN for this techie. :) Cheers, Bob s/y X SAIL R 8
G
gene
just one wire
one wire connects to the autohelm from the GPS wiring harness for GPS/Autohelm interface. Two other wires that connect are your hot and ground. That's it.
Dec 25, 2000
6,062
Hi Greg, check out my Garmin 178C ...
installation article in the 42 Knowledge Base...Improvements. Might be some helpful tips for you that I encountered interfacing our GPS with our autopilot. Terry
