I want to hook up my GPS 72 to my laptop via a USB port. Garmin only sells serial 9 pin cables then you have to go to an adaptor cable to get USB. BUT there is no power on a 9 pin serial port. I would like to get power so that batteries won't be an issue. The USB is a 5 V supply garmin say 8 or more volts BUT the unit runs on two AA batteries providing about 3 V. What to do???? My other Garmin is rigged to the VHF and uses the boats batteries. Is 5 V from the laptop enough voltage??? Is 100mA enough current?? Life would be much simpler and much less expensive if Garmin just sold a USB connector cable. But they don't I guess that they do the math and have decided that they would rather sell two $40 cables instead of just one.
