Gallons per Hour
- - Larchmont
Any estimates on gallons per hour for a westerbeke 30hp pushing a 33 foot (11,000lbs) at about 6 knots
Dec 25, 2000
5,916
Our 18 HP Yanmar burned about 3/4 GPH...
cruising an 9,000 pound Hunter at 3,000 RPM, while our 56 HP Yanmar burns about 1 1/4 GPH cruising a 26,000 pound Hunter at 2,500 RPM. Terry
Jun 3, 2004
347
Hunter 30_74-83 Lake Lanier, GA
Here's a link...
Here's a link to a PDF from Westerbekeshowing HP, TQ and fuel burn. Pat McCartin Inland Marine Diesel Buford, Ga imd_ga@hotmail.com
Jun 4, 2004
629
Sailboat - 48N x 89W
0.06 GPH/HP
The following rules-of-thumb are based upon a number of assumptions, so should only be considered estimating approximations. Refer to your individual engine manual for specific advice. Both gasoline and diesel engines use about 0.6 pound of fuel per horsepower used per hour. Diesel weights about 7.1 pounds per gallon, whereas Gasoline weighs about 6.1 pounds per gallon. Hence: Diesel Engines consume about 0.0845 (0.6 / 7.1) gallons per Horse Power per hour, at Wide Open Throttle. Gasoline engines consume about 0.0984 gal per H.P. per Hr. Hence, your 30 H.P. diesel could be expected to use about 2.535 Gallons per Hour at WOT. Since you’ll likely cruise at about 70% throttle, your actual cruising consumption could be estimated at about (0.70 x 0.0845 x 30) 1.775 Gallons per hour.
Jun 3, 2004
143
Hunter 33 Santa Barbara
GPH for new H33
JJ, After more than 100 hours on my 2004 H33, also about 11,000lb, I average about 0.75 gph at 3,000 rpm. This is a Yanmar 29 hp engine. If I push it above 3000 rpm, it goes to 1 gph. Michael
