galley sink
3
- - apollo beach
Our 1987 Catalina 30 galley sink is draining into the other sink. Any suggestions for unplugging it? Thank you.
Bill; formerly S/V Calico Dragon
Draining Slowly
I'm guessing that it is draining slowly?? If so then it sounds like there is a blockage in the line to the thru hull fitting below the point where the 2 sink lines come together. If not draining at all then are you sure the thru hull is open? Maybe the lever isn't opening the thru hull.
John
hose pluged
My C30 sink drain gets pluged and need to be blowen out with a garden hose every few weeks . I blow out my anchor locker and mystearing box at the same time .they get pluge also. John
