Galley sink
Oct 15, 2015
206
My current sink drain has been modified to flow into a manual guzzler pump and water exit from the side near the hull to deck joint. the original drain thru hull has been capped off. I can understand the safety issue of having the outlet high on the side but manually pumping is unfavorable. Besides that, there is lots of extra drain pipe going everywhere. I would like to hook the old system back up and have a clean installation. Problem is, I have never seen one. Is there a P trap, or just a straight pipe to the thru hull from the sink drain? Are there bronze reducer fittings for the sea cock with hose clamps? I could do this on my own either way but am looking for seasoned advice in case I have overlooked something. Pictures are worth a thousand words...Cheers.
Sep 24, 2008
346
Straight without a P trap. There are reducers available in every size you may need.The only reason to use a pump for the sink drain is if you have a boat where the sink is below the waterline - I have seen a few.
Dec 14, 2013
50
Albin Marin Vega 27 Venice
Hello Tim,I have added a couple of photos on the folder Albin Vega 3339 Spray, showing the sink-thru hull connection. I changed the sink thru-hull and respective valve with a Vetus bronze one and to fit the size of the sink outlet I used a plastic reducer fitting.Cheers,marco From: "alaskaflyfish@... [AlbinVega]" AlbinVega@yahoogroups.com To: AlbinVega@yahoogroups.com Sent: Wednesday, 9 March 2016, 5:07 Subject: [AlbinVega] Galley sink
#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571 --
#ygrps-yiv-1124540110yiv0559157571ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-mkp hr {
border:1px solid #d8d8d8;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-mkp #ygrps-yiv-1124540110yiv0559157571hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-mkp #ygrps-yiv-1124540110yiv0559157571ads {
margin-bottom:10px;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-mkp .ygrps-yiv-1124540110yiv0559157571ad {
padding:0 0;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-mkp .ygrps-yiv-1124540110yiv0559157571ad p {
margin:0;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-mkp .ygrps-yiv-1124540110yiv0559157571ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-sponsor #ygrps-yiv-1124540110yiv0559157571ygrp-lc {
font-family:Arial;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-sponsor #ygrps-yiv-1124540110yiv0559157571ygrp-lc #ygrps-yiv-1124540110yiv0559157571hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-sponsor #ygrps-yiv-1124540110yiv0559157571ygrp-lc .ygrps-yiv-1124540110yiv0559157571ad {
margin-bottom:10px;padding:0 0;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571actions {
font-family:Verdana;font-size:11px;padding:10px 0;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571activity span {
font-weight:700;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571activity span:first-child {
text-transform:uppercase;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571activity span a {
color:#5085b6;text-decoration:none;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571activity span span {
color:#ff7900;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571activity span .ygrps-yiv-1124540110yiv0559157571underline {
text-decoration:underline;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 .ygrps-yiv-1124540110yiv0559157571attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 .ygrps-yiv-1124540110yiv0559157571attach div a {
text-decoration:none;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 .ygrps-yiv-1124540110yiv0559157571attach img {
border:none;padding-right:5px;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 .ygrps-yiv-1124540110yiv0559157571attach label {
display:block;margin-bottom:5px;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 .ygrps-yiv-1124540110yiv0559157571attach label a {
text-decoration:none;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 blockquote {
margin:0 0 0 4px;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 .ygrps-yiv-1124540110yiv0559157571bold {
font-family:Arial;font-size:13px;font-weight:700;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 .ygrps-yiv-1124540110yiv0559157571bold a {
text-decoration:none;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 dd.ygrps-yiv-1124540110yiv0559157571last p a {
font-family:Verdana;font-weight:700;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 dd.ygrps-yiv-1124540110yiv0559157571last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 dd.ygrps-yiv-1124540110yiv0559157571last p span.ygrps-yiv-1124540110yiv0559157571yshortcuts {
margin-right:0;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 div.ygrps-yiv-1124540110yiv0559157571attach-table div div a {
text-decoration:none;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 div.ygrps-yiv-1124540110yiv0559157571attach-table {
width:400px;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 div.ygrps-yiv-1124540110yiv0559157571file-title a, #ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 div.ygrps-yiv-1124540110yiv0559157571file-title a:active, #ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 div.ygrps-yiv-1124540110yiv0559157571file-title a:hover, #ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 div.ygrps-yiv-1124540110yiv0559157571file-title a:visited {
text-decoration:none;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 div.ygrps-yiv-1124540110yiv0559157571photo-title a, #ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 div.ygrps-yiv-1124540110yiv0559157571photo-title a:active, #ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 div.ygrps-yiv-1124540110yiv0559157571photo-title a:hover, #ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 div.ygrps-yiv-1124540110yiv0559157571photo-title a:visited {
text-decoration:none;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 div#ygrps-yiv-1124540110yiv0559157571ygrp-mlmsg #ygrps-yiv-1124540110yiv0559157571ygrp-msg p a span.ygrps-yiv-1124540110yiv0559157571yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 .ygrps-yiv-1124540110yiv0559157571green {
color:#628c2a;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 .ygrps-yiv-1124540110yiv0559157571MsoNormal {
margin:0 0 0 0;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 o {
font-size:0;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571photos div {
float:left;width:72px;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571reco-category {
font-size:77%;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571reco-desc {
font-size:77%;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 .ygrps-yiv-1124540110yiv0559157571replbq {
margin:4px;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-mlmsg table {
font-size:inherit;font:100%;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-mlmsg select, #ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 input, #ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-mlmsg pre, #ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 code {
font:115% monospace;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-mlmsg * {
line-height:1.22em;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-mlmsg #ygrps-yiv-1124540110yiv0559157571logo {
padding-bottom:10px;}
#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-msg p a {
font-family:Verdana;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-msg p#ygrps-yiv-1124540110yiv0559157571attach-count span {
color:#1E66AE;font-weight:700;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-reco #ygrps-yiv-1124540110yiv0559157571reco-head {
color:#ff7900;font-weight:700;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-reco {
margin-bottom:20px;padding:0px;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-sponsor #ygrps-yiv-1124540110yiv0559157571ov li a {
font-size:130%;text-decoration:none;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-sponsor #ygrps-yiv-1124540110yiv0559157571ov li {
font-size:77%;list-style-type:square;padding:6px 0;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-sponsor #ygrps-yiv-1124540110yiv0559157571ov ul {
margin:0;padding:0 0 0 8px;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-text {
font-family:Georgia;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-text p {
margin:0 0 1em 0;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-text tt {
font-size:120%;}#ygrps-yiv-1124540110 #ygrps-yiv-1124540110yiv0559157571 #ygrps-yiv-1124540110yiv0559157571ygrp-vital ul li:last-child {
border-right:none !important;}
Jan 28, 2001
694
Not sure what you mean by capped off. Lyric has a straight but short run to a 1 1/4" ball valve. The original valve was a gate valve. Don't forget to attach bungs (tapered wooden plugs)to all the valves. WaltTo: AlbinVega@yahoogroups.comFrom: AlbinVega@yahoogroups.comDate: Tue, 8 Mar 2016 19:07:09 -0800Subject: [AlbinVega] Galley sink
Jun 6, 2007
132
Marco, The Guzzler drain system was on Shiva when I got her, I also thought it would be better to replumb the old drain, tried it and it would only drain when the boat was moving and then not very well. Howard
Dec 14, 2013
50
Hello Howard,I lived on board of my Vega for about 8 months (during summertime) since I purchased her in 2011. I used the sink regularly and did not have draining problems. I changed all underwater thu-hulls and respective valves upon advice of the technician who helped me in upgrading my boat but all the parts were still in good conditions. The Vega series III has the interior furniture a few cm higher than previous models but I do not think this makes a difference for draining. Maybe a problem (bottleneck) at the level of the old thru-hull valve?marco From: "Howard Barbour sailshiva@... [AlbinVega]" AlbinVega@yahoogroups.com To: AlbinVega@yahoogroups.com Sent: Wednesday, 9 March 2016, 18:09 Subject: Re: [AlbinVega] Galley sink
Marco, The Guzzler drain system was on Shiva when I got her, I also thought it would be better to replumb the old drain, tried it and it would only drain when the boat was moving and then not very well. HowardOn Mar 9, 2016, at 3:53 AM, Marco Baldan africanmarco@... [AlbinVega] wrote:
Oct 15, 2015
206
Marco, Thanks so much for the pictures of the galley sink and the tabernacle. So far you have been a source of invaluable information. I hope someday to return the favor. Cheers.... Tim Malone
