Galley sink drain
Brad
Does anyone have any suggestions or input about the galley sink drainage problems for the ODay 272. My 1986 has a thru hull "gravity" drain and it doesn't work worth a darn. This weekend, dirty water from dinner dishes was still in the sink Sunday morning. Is this typical? Do I have a clog in the line? Do I need to install a pump to evacuate the sink? Thanks, BB
Jeff
My 272
Had the same problem till I took a hose and just blasted the water through it. Cleaned it right up. Good luck Jeff
Mar 28, 2005
182
Oday 272 Baltimore
Ditto what Jeff said
I had a slow, then completely stopped drain. Took it apart over the winter, thinking perhaps the problem was in the through-hull. It was in the line just above the seacock. Looked like my kitchen drain after I try to run too much through the disposal too quickly. Disassembly, reaming out, then flushing with hot soapy water cleaned it out. It now runs fine. I keep a fine mesh strainer in the sink drain, to catch any bits and toss them overboard rather than run them down the drain.
Brad
Thanks!
Thanks for the input guys. Sounds like I just need to do a little "non-Drano" pipe cleaning. That'll be a nice little project for the long weekend. Fair winds and happy sailing!! BB
Jun 4, 2004
174
Oday 272LE Newport
I always wondered what that solid #8 coated
... wire with a little loop handle was about 3 ft. long ... until that sink pluged up the first time. Since it is a straight run right out the hull all you have to do is poke it down a few times to clear anything. It sits right next to the spare tiller ... at least on "Seven" Vic "Seven"
