Last spring (2010) when I launched the boat after winter lay-up there was a small leak at the connection between the through hull and the fitting which connects to the through hull. There is a plywood "gasket/spacer" between the thorough hull and the nut which compresses the drain to the hull. Eventually the wood gasket swelled up and the leak stopped. In addition to that leak there was a leak near the ball valve. With those two leaks I think it is time to replace the drain components. My question is: what are these things made of in a 1980 O'day 28? It is a plastic of some sort. It is yellow/tan in color and has a non smooth finish. Are these items common hardware items at marine supply stores? Do I have to use the same material as the original or will a metal or other type plastic work as well? I am a bit at sea on this subject so any help is appreciated.
Thanks,
Mike
Thanks,
Mike
