galley in a catalina 22
9
Catalina 22 Beaver Lake Sailing Club
Thinking of buying a Catalina 22 and can't find out how the galley works - does it fold/slide back into somewhere under cockpit? Or just detach and lift out? (Some owners say they sold their galley!)When galley is put away, what's left? a settee under it or what? Also, is there storage under cockpit seats reachable from cabin?
BarryL
May 21, 2004
1,064
Info
Hello, I guess you are are looking at older boats, pre 86 or so? Anyway, on my C22, a 1981, the galley was the sliding model with a two burner alcohol stove, sink with 5 gallon water tank, small ice box, and drawer. The entire affair slides and stores under the starboard cockpit settee. When the galley is stored there are cushions in the cabin settee. To use the galley you move the cushion and slide the galley into the cabin. The sink drains into a bowl molded into the boat. You can remove the galley by just lifting it out of the boat. It's heavy, probably about 75 lbs. The first year we had the boat the galley was on board but we never used it. The second year I took it out and stored it in the basement. I replaced it with a large storage box that got much more use than the galley. Regarding storage under the cockpit seats: If you move the port side, rear dinette seat you can access the storage under cockpit. In fact, I once locked my keys in the boat, and I had to climb down into the cockpit lazarette then wiggle forward, climb into the cabin, get my keys, then climb back out too! My understanding is that the cabin layout in the 86+ boats is different. Barry
Bob B.
C22 Galley
Hello Boatergirl: My 1980 C22 galley slides aft out of sight. It rides on a moulded in track. When it is stowed under the cockpit seat the settee cushions can be put in place. It lifts up & out & resides in my basement. Regards,Bob B.
Bob B.
C22 Galley #2
Boatergirl: My last response should have included a photo but it disappeared!! Will try again. Bob B.
