K
Ken Nott
I have a 1973 Ericson 29 with a galley icebox which has a leaking drain hose. The attachment of the drain hose to the drain fitting under the icebox is completely inaccessable from underneath. Does anyone know how to remove the fitting from the icebox? Is it just glued in? Is there a screw fitting under the icebox into which the top piece is screwed? The drain hole is about 1" (maybe less) in diameter. There is a single cross bar across the hole to prevent stuff from falling through. Any suggestions would be appreciated. Thanks.
