Joan
Do you have a rigid boom vang by z-spar on your 29.5? If so, is small diameter portion or large diameter section attached to the boom. Which direction does the v-cleat face? Ours continually pops out. Either it is rigged incorrectly or it needs to be modified. Glad we didn't have all your problems on our 29.5. Initially we had leaks on stern and starboard side, while still under warranty. Dealer pulled rub rail and discovered that the aim on person drilling holes to attach hull to deck was awful and holes had actually been drilled into hull. Fixed that and no more problems. Also we have a groove for draining on our ports so they don't leak. Have not had engine problems. Do fly a balooner and that is great. We really like the sailing on this boat! Joan
