Fynspray galley pump rebuild
3,086
ODay 35 Beaufort, NC
My boat has a Fynspray pump in the galley to drain the icebox.
I picked up the "rebuild kit" and took the top nut off the pump but I can't pull the piston out of the bore? Has anyone rebuilt one of these pumps? Do I need to unscrew it from the counter and disassemble from underneath? Any help will be appreciated. It is probably easier to just drain the ice box into the bilge with a shut off valve, but I don't want a hole or an unworking pump in the galley counter. A new pump like this is over a hundred bucks. A lot of money for something that takes 50 strokes to pump a gallon of water.
Thanks,
Dave
