Fwd: Re: md6a engine panel.
Oct 30, 2019
31
pat colligan coonhopper2000@... wrote: Date: Mon, 3 Jul 2006 12:16:01 -0700 (PDT)
Subject: Re: md6a engine panel.
To: AlbinVega@yahoogroups.com
ATTENTION VEGA VOLVO OWNERS! Have series two Vega with original MD6a and panel. Trying to find someone that knows something about the 3 lights on my engine instrument panel as well as the three pull out switches. Im sure one switch must be for lighting the oil pressure guage and water temp guage. My lens on the three lights are pretty old but looks like I had a blue ,red and orange. I think the blue would be oil pressure, the orange charging and the red temp,but not sure. I believe the orange lite should come on when the dynastarter is not charging. The blue lite should come on initially and then go out to indicate oil pressure is up and good. Can anybody confirm these functions? Panel itself, (photo attached) looks like bronze beneath the salt and corrosion and will try to polish that up. Cheap lens for lites are available at auto stores here but hope to find originals from Volvo. They have a large spring behind lens which looks like it did a good job of keeping
water out of lights and lens. Tach isnt working on right side of panel which could be due to wires disconnected or mabe bad sending unit. Any feedback or imfo on function or spare parts is appreciated! Yearn for the day I can sail instead of work on these things.Have sailed 2 days in 3 years... Pat Colligan V2137 "Puffin" Marathon, Florida
John Starace giani28582@... wrote: Hi Group
I'm having a mainsail cut for sv/Puffin!
Does anyone out there have the dimentions of the sail slides that fit inside proctor mast and bolt rope diameter for foot of sail.
Thanks a bunch.
Happy 4TH
Gianni
Dec 11, 2007
179
- - port st. lucie,fl.
Pat-
On my panel the lights are left to right; gen chging, alt chging,
and oil pressure. The switches are running lights,mast light
(steaming) and spare. The one above the switch is the blower. I
replaced all the lights with units from Radio Shack. The originals
were brittle from age and fell apart.
Richard, V1812
Oct 31, 2019
84
Thankyou Richard, that was very helpfull. Curious if you have the same panel. Vega group mail would not accommodate photo attached. If you have email can send photo of mine. Are the lites designed to come on when they fail? Pat V2137
Richard, V1812
Dec 11, 2007
179
-Pat-
Yes they come on initially when you turn on the key, then go out
after engine start. Same as the lights on a car. You can contact me
at coe.richard@... if you want. My panel probably is same as
yours, I have only one instrument, a temp gauge.
Richard, V1812
-- In AlbinVega@yahoogroups.com, pat colligan coonhopper2000@...
wrote:
Oct 31, 2019
84
Tom, Thanks for note, unfortunately it doesn't match my panel... Can send you a photo if you have email address. Pat
"Thomas D. Hamill" tdhamill@... wrote: pat:
The owner's manual has a graphic of the engine panel.
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
