Fuses M25-xp
Pil
Jun 23, 2025
1
Catalina 30 Montreal
Hi,
I've been following how to upgrade wiring for a M25 XP. I'm done with most of the work except the fusing. 2 questions are still unanswered.
I'm installing a selenoid for the glow plugs. What size fuse should I use
for the starter plug to selenoid wire? 30 amp?
I also saw that it was recommended to put a midi fuse on the panel feed red wire (starter lug to panel). Again, no idea of fuse size here.
Thanks
Welcome to SBO. I see you have a Catalina 30. The boat manual has a wiring diagram, if you are following that in your rebuild. If putting in additional upgrades, the best practice is to select a fuse based on the wire size you are using.
