I did this project over the winter.
John,I replaced my old fuse panel on my '86 C-36 with four panels from Paneltronics. All I had to do was drill four new screw holes to line up with the teak frame. They sell some panels that are 5 1/2 W by 8 1/4 H that fit into the teak frame very nicely.I did order a custom frame, but got the measurements wrong (and wasted the money). But the original teak frame looks better anyways. The only issue that I have is there is a gap in the center of the panel where the lock is that is not covered by a panel. You could probably order a blank to fit that space, though. It is probably 1/2 inch wide. I needed to relocate my Link 10 monitor to another space, but that was pretty easy as well.I ordered two 2306 DC panels, one 2305 AC panel, and one 2201 Battery switch panel. I got the Premier line so that I could have the backlit labels and LED indicators. Total was about a boat buck including about $400 for the unneeded frame. Anyone need a metal frame?
The only thing I have left to do is rewire all the circuits. Other than that, my electrical system is basically all new.Enjoy the project. I learned a lot doing this.Les Murrays/v Ceilidh'86 C-36 #560
