Furling the Genoa
thaeni
Sep 28, 2008
120
Hunter 33.5 Chicago
Instead of turning into wind and furling, is it OK to furl (using winch) under full sail ?
Nov 26, 2012
1,654
C&C 40-2 Berkeley
Actually I prefer this method. Flagging the sail, especially in heavy wind damages it. You do have to be careful that the furler does not get hung up as the winch is powerful enough to break it.
Jul 7, 2004
8,502
Hunter 30T Cheney, KS
If you had to I suppose. Seems like a strain on the equipment. I don't turn full into the wind, I stay off the wind just enough so that there is some tension on the sail and it furls up tight.
Hunter 34 Alameda CA
I turn down wind and blanket the jib with the main. Then it rolls up by hand. My furler instructions say to never use a winch. Too much risk in damaging it. I almost said I turn off the wind, but that sounded like I controlled it with a switch.
Likes: Roland5048
Jul 14, 2015
840
Catalina 30 Stillhouse Hollow Marina
I never use winch and furl in any direction by just releasing some of the tension. I do not let it flog.
Feb 7, 2016
1
hunter 30 portland
I belive it best to let the conditions dictate what is best. Any time you can keep excessive loads off any equipment you are doing yourself a favor. If you get yourself behind the boat and need the winch to roll up, use it. Then remember how you got yourself into that situation.
Kopite
Mar 11, 2015
110
Catalina 27 Monroe MI
As with the others, I now ease off just enough to relieve tension and furl by hand. Apart from damage from flogging the sail, trying to furl with the sail and sheets flapping can lead to a half deployed tangled mess, as I found out one day when the wind picked up and I was solo ...
What furler do you have. Most say you shouldn't ever use a winch. My ProFurl says you can. I've only done that once in 18 years. Use the good advice offered here. It's technique, not brute force, that should be applied.
1,096
CS 30 Toronto
Sail on a beam reach. Much easier and lighter to reef. The line is too thin to use a winch.
May 12, 2004
1,505
That is also how I teach my students to furl the jib. One extra step I show them is to take a few turns then hold the furling line and pull the sheet tight. Repeat until the sail is furled. This gives a tight roll and helps prevent the candy cane effect.
Oct 6, 2007
1,165
Hunter H30 1982 Chicago IL
That is pretty much what I do all the time, often solo. Furl the genoa while headed downwind blocked by the main (no need for winch) and keep a little tension on the sheet for a neat roll.
I finish with two or three more complete turns wrapping the sheets around the roll, then cleat both sheets and the furler line to prevent accidental unfurling. Every year I see one or two boats in the harbor with shredded head sails on windy days or after storms because someone didn't bother to secure those lines.
Mark48
Mar 1, 2008
166
Hunter 34 Milwaukee
Dalliance makes an excellent point about the 2-3 wraps around the roll and cleating off the sheets and line. Common occurence that should be made as a point by anyone giving lessons.
May 12, 2004
1,505
Yes, I always do that and teach it. We call it a storm wrap and stress that it should always be furled that way.
Likes: Dalliance
