Harken
We added a furling system last year. We went with a Harken Unit 0. The Unit 00 would have also worked, but the Unit 0 was a bit beefier. We don't mind sailing when the weather gets a bit on the rough side, so we wanted the extra piece of mind. If you tend to only go out in calm conditions, you could consider the 00.Once installed, the Unit 0 ran us around $1400 from pyacht.com. This kit included everything but the sail.I believe the Unit 00 will run around $850 for the kit.We did the installation ourselves which also saved us some $$$, making it easier to justify the more expensive unit. Assembly was not too difficult, but just make sure you measure your headstay correctly. If you don't the mistake could be costly.If you have any other questions, please feel free to contact me at: michael_gordon @comcast.netGood LuckMichael Gordon
