Furling System
A
Austin
If anyone has some good advice about adding a furling system on a 87 23'. Please write on, looking at adding one this spring, and would like comments on brands, etc.
Steve
Try CDI
Give CDI a call and ask about the specific application for your boat. Then shop for it in all the discount catalogs. See them at www.sailcdi.com Major advantage is the fex luff with a life time warranty made for trailer sailors and little maintenance.
Jon Bastien
Don't forget...
Hi, Ray! I was looking at adding a furler to my H23, and after doing some research, I decided that when I finally have enough $$ to do this upgrade, I'm going with the CDI. It seemed to be the most compatible with the boat. Something to consider, though, is that the tack of the jib attaches to that short cable in the anchor locker. What this translates to, ultimately, is that you will have to put together some sort of system to attach the furler to the base of the forestay, and also raise the furling drum a few inches off the deck so you can still open the anchor locker. There are other H23 owners out here who have added furlers, so it CAN be done, but I've never actually seen one. Good luck, and let us know what you decide! --Jon Bastien H23 '2 Sheets to the Wind'
Steve Lucas
Furler
I purchased my 23 with a furlex furler attached. I singlehand the boat 90% of the time and love it. If I had to replace it and money wasn't a factor, I would go with the Harken ( $750) but since thats alot of beer money I would probably go with the CDI ($400). I think it's on sale @ JSI.. www.jsisail.com
A
Austin
Furler or Beer Money
Thanks for the advice, will let you know what I decide and how it works. Also I agree with Steve - that is alot of beer money.
Ron Fraboni
Good Price For CDI
I bought a CDI furler for my 26 and got a very good price from Defender Industries - they have a web site and 800 #. If what you need is a standard item, the price is much lower than if it is a special order for them. Call CDI and they can tell you what furler model you need and how to hookup the hardware. Good luck.
Jerry Swalley
Added Furler to H23
I added a Hood "Seaflex" furler to my '85 H 23last spring. If your forstay is attached in the anchor locker like mine, you will need to attach two plates about a foot long by 1" wide to the bottom of the furler so it will clear the anchor locker. The plates straddle the forstay clevis. I used a longer pin that goes through both plates and the forstay clevis. The furler worked fine except that the sheetmetal guard isn't attached well. It was donated to Neptune one afternoon. I made another and attached it with screws. If you'd like, I can send you a picture or a sketch via e-mail. I'm at swalleyjc@aol.com Regards, Jerry
K
Kris Cox
Hood Seaflex
I purchased my '86 H23 with a Hood Seaflex furler. I've had two problems with it. First, when my mast was down and the luff extrusion (the thing that slides up the forestay and which the sail then slides through) was snaked from bow to stern, the extrusion snapped. Hood's response to this was excellent, and I had a replacement within 2 days. Second, I agree with Jerry, that the sheetmetal guard is NOT attached well. It's held in place with two friction pins that don't hold well. On one occasion, I lost my pins to the water. To my surprise, Hood also replaced these for free. Then, on my next voyage, the pins popped out while unfurling and I lost the entire metal guard. I called Hood about this one, and they didn't call me back. I guess they've had enough of me! The purpose of the guard is to hold the line around the furler unit, and keep it from uncoiling around the base of the forestay. I have been using it without the guard with no problem--I just have to pay attention to keep tension on the furling line so it doesn't have a chance to slip around the base of the furler. Happy Sailing! - Kris Cox added a Hood "Seaflex" furler to my '85 H 23last spring. If your forstay is attached in the anchor locker like mine, you will need to attach two plates about a foot long by 1" wide to the bottom of the furler so it will clear the anchor locker. The plates straddle the forstay clevis. I used a longer pin that goes through both plates and the forstay clevis. The furler worked fine except that the sheetmetal guard isn't attached well. It was donated to Neptune one afternoon. I made another and attached it with screws. If you'd like, I can send you a picture or a sketch via e-mail. I'm at swalleyjc@aol.com
Paul Jordan
Added CDI to H25
Back in November I helped my marina neigbor install a CDI unit on his 1980s vintage H25 (don't remember the year of the boat). The kit was very complete and it took us a total of about 3 hours to install it and sail away from the dock. Be warned, it really is a two person job (at least parts of it are). Also, do not forget to figure in the cost of having your headsail modified to work with the furler (and have a UV cover). My friend's dealer included modifying his headsail as part of a package price. The outcome: the new furler owner is absolutely delighted with the result. He single hands alot and says it has changed his life.
Dave Condon
furler
There are many goood furling systems out there but for the money and flexibility on trailerables, I suggest the CDI or flexible furler. Joe who owns that company does stand behing his product. By the way, he knows I am crazy but guys, I do have fun even though I am crazy or am I? Crazy into the wild bule yonder
