A Little TLC
Michael, I have a Stream Stay on a 88 Hunter 30. I have had some problems with the system over the years. The lower unit works pretty well but the top swivel is usually the problem child. I completely disassembeled both units several years ago and cleaned all parts and lubricated with Mac Lube. The unit is equipped with plastic (Torolon) bearings and they might be worn, but mine were OK. I reinstalled the system and each year I relube the top swivel with the Mac Lube while still on the foil. Since then the unit is doing pretty well. It ain't no Harken but I am still $1600 ahead. I have a little information on the unit If you will send me a fax number I will try to send you the info.There is an outfit in NY I think that bought the rights to the system and they say that they have improved the design but it was quite pricy and I was leary of throwing good money after bad.Frank
