Furling Mainsail Upper Swivel Lubrication
Jun 21, 2004
3,043
Beneteau 343 Slidell, LA
What do you use to lubricate the upper swivel on your roller furled mainsail? Currently replacing the main halyard & furling line on the furler worm gear as well as servicing the bearings on the gear. The mainsail is removed, presenting a good opportunity to service the upper swivel. The furler is one US Spars model. Do you lubricate it, or does it require disassembly & rebuild?
