Furling Main
May 28, 2015
4
Beneteau 35 Warwick
Has anyone out there ever tried to remove the furling unit from their mast (replace the boom) and use the mast with a traditional main? There is a second channel and it seems like it should be an option but I was curious if anyone had ever done it.
As you can probably surmise from this question, I'm not a fan of the furling main.
Any thoughts are appreciated.
Cheers
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
My extremely prejudiced reply:
Get rid of the furling main And don't look back! Everyone I know who has one has had problems at all the wrong times.
You shouldn't really have to replace the boom, and you could potentially leave the furling hardware inside the mast if you could prevent it from rattling.
Nov 24, 2012
586
I agree with Dougm! With a track (I.e. Tides marine) and a sail bag. You can drop a main and stow it faster than you can furl a main. Plus you'll have better sail shape.
Gunni
Mar 16, 2010
5,937
That additional track is likely a trysail track, not a replacement for a conversion. If you are serious about this plan on a new rig, including boom, line clutches and maybe even a winch upgrade.
Oct 29, 2006
388
Beneteau 381 Olympia, WA
What's your main issue with it? Are you looking for more performance or having issues furling/unfurling it, or both I guess? You'll never get low wind performance but furling and unfurling can be easier with a few tricks, many of which you'll probably have figure out how it works best for you.
For me I've marked where the main sheet and vang needs to be to have the boom at the right angle. My car doesn't have a bearings on the car so I've moved the car stop back to mid boom to ease the angle... few things like that makes all the difference.
I don't think furling main will ever give performance but I think I have as much fun on the water as everyone else, well once I get my propane, head, and swim step shower fixed that is... :)
