Furling the Main on a Beneteau 343
HI:
This has also been a problem for others in the 323-343 range. I have observed that the furling and re-furling can cause difficulties. For myself, the biggest issue occurs because I have a bimini which is raised fairly high over the cockpit. So you might ask, what does this have to do with matters. Well for me, my boom will not fit 90 degrees perpendicular to the mast (the boom tends to form about a 85 degreem angle into the mast.
I have found that if you do not get this 90 degree angle boom to mast, you will most certainly have a problem with furling. So what is the fix?
For me, before unfurling, I swing the boom over the starboard side of the boat. Then drop down a little on the topping line until I get the 90 degree angle. Now I am ready to unfurl.
Once the sail is out, I can lift the boom up to the 85 degree angle of the boom into the mast and sail all day with no problems. That is until I have to reef, then I must be particularly aware of this 90 degree angle again, so again drop the boom on the starboard side, drop the topping line, and the 90 degree angle starts all over again.
A pain in the rear, maybe? The alternatives, you could try raising the the boom, but then you could have sail problems again. Or I could cut the tubes on the bimini, but they I would lose the 6 ft clearance in the cockpit.
Another issue when furling that I have found, is to be certain that their is some a slight back pressure on the line when you furl
Finally, check the batten covers, they can get stuck at times. I actually had my covers made bigger and re-sewed, but I think this is a lesser problem.
Hope this helps.
Alan
